Audacity 2.0.5 unresponsive - mod-script-pipe[SOLVED]
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by n6ac » Thu Jan 02, 2014 3:25 am
Audacity 2.0.5 unresponsive in Mavericks - the little splash screen opens, then a module loader box, but if I say yes try and load it freezes up ...
Screen Shot 2014-01-01 at 7.09.48 PM.jpg (28.15 KiB) Viewed 828 times
n6ac
Re: Audacity 2.0.5 unresponsive in Mavericks
Permanent link to this post Posted by Gale Andrews » Thu Jan 02, 2014 1:50 pm
You don't need modules unless you are a software developer. The module won't load unless you have compiled Audacity and the module on the same day.
In the "Audacity" folder, open the "Modules" folder to check that you have no files or plug-ins in there you want to keep. Then having copied any files you want to somewhere else, delete the "Modules" folder.
Re: Audacity 2.0.5 unresponsive - mod-script-pipe[SOLVED]
Permanent link to this post Posted by n6ac » Fri Jan 03, 2014 2:05 am
thank you!
n6ac
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
