No Playback on MacBook (loud click instead)
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at http://www.audacityteam.org/download/.
Re: No Playback on MacBook (loud click instead)
Permanent link to this post Posted by kmarty » Tue Dec 03, 2013 7:30 pm
Gale Andrews wrote:It's interesting that the second QuickTime play fixes Audacity playback while you are logged in. Does Audacity playback still work if you quit and restart it immediately?
Yes, it is still work.
Gale Andrews wrote:If you play a file in QuickTime twice, then wait a couple of minutes before playing in Audacity, does it still play?
After 10 minutes it still work. Also when I let laptop sleep, when resumed after two hours it still work. After reboot it still work. I have to shutdown and then power on to induce this issue (sorry if I somewhere wrote "reboot" previously, it has to be shutdown, about second wait and then power on).
"antipop" doesn't help (I made 10 minutes length tone, whole was played without any sound - except first beep and loud click). Nothing happened, although "antipopd" was launched.
When I try manually what "antipop" should do (i.e run "say" command with space every ten seconds), then after fifth say " " tone began audible (btw. it means that it would take about 50 seconds until Audacity start playing when "antipop" do what should do).
EDIT: I'm trying to find what was wrong, because "antipopd" is just a shell script with endless loop with say " "
EDIT2: Ah, AntiPop installer firstly starts "antipopd" as root. And launchctl wasn't quite successful when it should start under logged in user.
kmarty
Permanent link to this post Posted by Gale Andrews » Wed Dec 04, 2013 12:25 am
OK thanks for testing.
Can you confirm if you shut down the Mac, open Audio MIDI Setup, look at the output settings for built-in audio then start Audacity, do settings change in Audio MIDI Setup? If you generate a tone in Audacity and try to play it, do settings change then?
Can you confirm if you shut down the Mac, leave Audacity alone then play a file in Quick Time, does it click the first time you play it, and then play OK second time?
Permanent link to this post Posted by kmarty » Wed Dec 04, 2013 9:32 am
Gale Andrews wrote:Can you confirm if you shut down the Mac, open Audio MIDI Setup, look at the output settings for built-in audio then start Audacity, do settings change in Audio MIDI Setup? If you generate a tone in Audacity and try to play it, do settings change then?
Are we talking about this?:
Snímek obrazovky 2013-12-04 v 10.08.41.png (50.47 KiB) Viewed 1563 times
(Vestavěný mikrofon = Internal mic, Vestavěný vstup = Internal input, Vestavěný výstup = Internal output)
After fresh power on:
int. mic: 44.1kHz, 2ch/16b int, M = 0.083 (-10dB)
int. input: 44.1kHz, 2ch/16b int, HW freq converter disabled, 1: 0.5 (0dB), 2: 0.5 (0dB)
int. output: 44.1kHz, 2ch/16b int, 1: 0.254 (-28.5dB), 2: 0.254 (-28.5dB)
After Audacity is launched (but nothing else):
After tone generated and (unsuccessfuly) played in Audacity:
I.e. no change.
Gale Andrews wrote:Can you confirm if you shut down the Mac, leave Audacity alone then play a file in Quick Time, does it click the first time you play it, and then play OK second time?
When I power on Mac, didn't touch anything except I play audio (through Quicklook in Finder), it plays immediately without any issues. First time, second time, doesn't matter.
When I power on Mac, launch Audacity (just launch, nothing else), try to play audio through Quicklook in Finder, it also plays without any issues. But when I try to play audio in Audacity (for example generated tone) an issue appears.
kmarty
Permanent link to this post Posted by Gale Andrews » Wed Dec 04, 2013 3:55 pm
Thanks again for testing (yes I meant the Audio MIDI Setup utility).
So this isn't a problem with Audacity making visible settings changes to the audio device, and not a problem when it queries the audio device on launch. It just occurs when you play in Audacity.
I suppose you could rebuild current Audacity with http://code.google.com/p/audacity/source/detail?r=12231 and http://code.google.com/p/audacity/source/detail?r=12232 reverted to isolate if those commits were the cause. Do you build Audacity on Mac ( http://wiki.audacityteam.org/wiki/Building_On_Mac ) ?
Permanent link to this post Posted by kmarty » Wed Dec 04, 2013 6:07 pm
Gale Andrews wrote:Do you build Audacity on Mac?
Not yet. It will be first time.
kmarty
Permanent link to this post Posted by kmarty » Wed Dec 04, 2013 8:22 pm
Hmm, probably not :-(
I'm stuck at compiling wxWidgets 2.8.12 on OS X 10.9
kmarty
Permanent link to this post Posted by Gale Andrews » Thu Dec 05, 2013 8:21 am
kmarty wrote:Hmm, probably not :-(
Are you following http://wiki.audacityteam.org/wiki/Build ... _wxWidgets ?
You do need Xcode 5.0 or greater on Mavericks. I'll update the Wiki page presently to say that.
As you are building widgets from a script, all the preceding steps on http://wiki.audacityteam.org/wiki/Building_On_Mac must be followed.
If rebuilding with older PortAudio doesn't work for you I might try to do it, but the Audacity build system has certain quirks at the moment.
Permanent link to this post Posted by kmarty » Thu Dec 05, 2013 11:01 am
Gale Andrews wrote:Are you following http://wiki.audacityteam.org/wiki/Build ... _wxWidgets ?
Moreless.
I already have cmake (version 2.8.12) and pkg-config (version 0.28). I believe that's enough.
wxWidgets: I missed that it really needs sdk 10.4u (i.e. Xcode 3.2.6)
Conclusion: No, I didn't exactly follow that page. Sorry about that.
(EDIT: Updated to make post more clear and correct)
kmarty
Permanent link to this post Posted by Gale Andrews » Fri Dec 06, 2013 8:27 am
I've updated the Wiki page http://wiki.audacityteam.org/wiki/Building_On_Mac .
The whole process on that page depends on linking Xcode 3.2.6 with later Xcode. This is OK when updating to Mavericks from earlier OS X as I did, because you can install Xcode 3.2.6 on Mountain Lion or earlier.
I really don't know if you can install 3.2.6 on Mavericks. The only search result I can find is that 3.2.6 installation crashes then the machine won't reboot properly until you reinstall Mavericks. :evil:
I'll see if I can find any more out about this.
Permanent link to this post Posted by Gale Andrews » Sun Dec 22, 2013 4:47 pm
Gale Andrews wrote:I've updated the Wiki page http://wiki.audacityteam.org/wiki/Building_On_Mac .
I'm still trying to find out. Did you make any more progress?
If you reduce or increase Audio to buffer in the Audacity recording preferences, does it make any difference to the click problem?
PreviousNext
Return to Mac OS X
Who is online
Users browsing this forum: Gale Andrews and 4 guests
