Skype recording edit separate channels
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by charliek_98 » Thu Mar 22, 2012 6:39 pm
I have a Skype recording that was a .mov file and I've opened it in Audacity 2.0. In Audacity it is 2 tracks; one for the caller and one for the person on the other phone. I would like to split this tracks so I can edit each one separately. Any ideas on how to do this?
Thanks,
Charlie
charliek_98
Re: Skype recording edit separate channels
Permanent link to this post Posted by kozikowski » Thu Mar 22, 2012 7:20 pm
If you already had two separate people as stereo, use the drop-down menu to the left of the track and "Split Stereo Track." You can then edit and filter each side independently of the other and recombine them the same way.
If you meant to say you had one track with two people mixed together on it? No. That's why we recommend Pamela Business or Pamela Professional or Total Recorder on Windows machines. That will give you near and far on separate tracks and you can edit or apply filters as you wish.
Did you get this split track from another Mac? How did you do that?
Permanent link to this post Posted by charliek_98 » Thu Mar 22, 2012 9:36 pm
Thanks. I will try that.
I'm using a Mac and a program called Call Recorder, which creates this file.
Charlie
charliek_98
Permanent link to this post Posted by charliek_98 » Thu Mar 22, 2012 9:47 pm
Works perfectly. Thanks.
charliek_98
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 10 guests
