Audacity does not start or does not respond
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by giopik » Thu Mar 22, 2012 8:18 am
Hi all,
I've recently downloaded 2.0 in my mac mini core 2 duo 1,83 ghz 2MB ram
I've mounted the .dmg and i've copied it the folder in my apps.
I've launched the program and after 60 seconds the icon stay in dock firmly but i could access to te application only the first time.
after some test I quit the program and after that I cannot access to the program ( the icon is in the dock but does not respond....)
Can someone help me?
thank you in advance
Gio
giopik
Re: Audacity does not start or does not respond
Permanent link to this post Posted by billw58 » Thu Mar 22, 2012 2:42 pm
Inside the Audacity folder, create a folder called "Portable Settings".
Using TextEdit, create a file with exactly this content:
Code: Select all
NewPrefsInitialized=1
[AudioUnits]
Enable=0
GUI=0
[VST]
Enable=0
GUI=0
Rescan=0
Save this file in the Portable Settings folder as "audacity.cfg".
Now try starting Audacity.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
