Noise removed in Audacity but not in exported file
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Re: Noise removed in Audacity but not in exported file
Permanent link to this post Posted by steve » Fri Mar 23, 2012 1:08 pm
Robnonstop wrote:i mark part of the file with just noise.
Effect > Noise Removal > Get Noise Profile
Select everything (Cmd+A)
Effect > Noise Removal > OK
I play the file, no noise. I think I’m done and can just export the file.
That sounds just right (though tweaking some of the settings in the Noise Removal effect may improve the results, but we can come back to that later).
Robnonstop wrote:I export the file and change nothing (just noticed it's not possible to change the options anyway)
Could you give a step-by-step breakdown of exactly how you are doing that.
It sounds like you are doing everything right, but there must be something not quite right because the exported file should not sound different from the track in Audacity.
Permanent link to this post Posted by Robnonstop » Fri Mar 23, 2012 4:18 pm
I expected it to sound the same.
I just go to File > Export, leave the setting to WAV and choose a place and filename.
Robnonstop
Permanent link to this post Posted by steve » Fri Mar 23, 2012 4:26 pm
If you import the processed file back into Audacity and play it, how does it sound?
What program were you using to play the exported file?
Were you listening with the same headphones/speakers?
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
