VST plugin problem!
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
VST plugin problem!
Permanent link to this post Posted by derek12 » Thu Mar 15, 2012 7:54 pm
Hi I am new to this forum :)
I have Mac OS X Lion and Audacity 2 installed from the DMG and I am not able to use DX Reverb light plugin from ANWIDA because it does not appear in the effects menu, I have moved the .vst file to Audacity plugin folder and I have checked the reescan plugin at the next restart but still won't appear, doe anyone know how to solve this?
Many thanks :)
derek12
Re: VST plugin problem!
Permanent link to this post Posted by kozikowski » Thu Mar 15, 2012 8:38 pm
How did you get the plugin download? Specifically. Koz
Permanent link to this post Posted by derek12 » Thu Mar 15, 2012 8:54 pm
http://www.anwida.com/download.asp
DX Reverb Light
Mac OS X (VST)
Decompressed the .sit file and got the installer, custom directory to select /applications/audacity/plugins and the file "DX Reverb Light.vst" is created there (at first I've installed into the default directory (/library/audio/plug-ins/vst) but wasn't working so I tried to install into the plugins folders from Audacity, but Audacity won't recognize it (won't appear in the effects menu) despite trying everything :(
derek12
Permanent link to this post Posted by kozikowski » Thu Mar 15, 2012 9:31 pm
You used to need "VST Bridge" software to get Audacity to recognize VST plugins. Maybe that's still true.
http://manual.audacityteam.org/help/man ... st_install
Permanent link to this post Posted by kozikowski » Thu Mar 15, 2012 9:34 pm
No luck. If the plugin tries to launch fancy graphics right at the beginning, it's not going to load in Audacity. Audacity doesn't support VST graphics.
Permanent link to this post Posted by derek12 » Thu Mar 15, 2012 10:00 pm
Hmm strange, I have tried with a friend's Windows computer and using Audacity 2 and DX Reverb and it loads and works fine even the GUI but on my Mac is impossible! Is the Audacity VST support for Mac more limited or something? Anyway I will try VST bridge. Thanks, I need this plugin because I tried it with Windows and gives good reverb effect that I cannot get with Gverb :)
derek12
Permanent link to this post Posted by Trebor » Fri Mar 16, 2012 7:16 am
Q: I installed the VST plug-ins for Mac but my host application does not recognize them. What's the problem?
A: The Mac plug-ins require MacOS X to work. If you are using MacOS X, check that your audio host application supports Mach-O plug-in format. This is required to use the plug-ins.
http://www.anwida.com/faq.asp
viewtopic.php?f=17&t=32150
Trebor
Permanent link to this post Posted by derek12 » Fri Mar 16, 2012 8:44 am
I have read those links way before and I do not understand them, but I have saw now that it is for PPC and not Intel, despite it saying that they are Universal binaries (the modify year is 2003l) so I will use a Windows machine to use it.
derek12
Permanent link to this post Posted by Gale Andrews » Fri Mar 16, 2012 10:47 pm
kozikowski wrote:You used to need "VST Bridge" software to get Audacity to recognize VST plugins. Maybe that's still true.
Please read the FAQ you cited :)
There is no need to add the VST Enabler which was required by previous versions of Audacity.
kozikowski wrote:Audacity doesn't support VST graphics.
Audacity 1.3.8 or later has a specific setting in the Effects Preferences "Display VST effects in graphical mode."
Return to Mac OS X
Who is online
Users browsing this forum: kozikowski and 7 guests
