Crashes on close
Crashes on close
Permanent link to this post Posted by tpx » Sat Apr 14, 2018 6:03 pm
almost every time on close, bam! (see attached)
did a clean uninstall of previous vs then install latest
its freaking annoying, like that save project prompt, but lets focus on this 1st
tpx
Re: Crashes on close
Permanent link to this post Posted by steve » Sun Apr 15, 2018 11:37 am
Which version of Audacity are you using? (look in "Help menu > About Audacity" for the version number)
How exactly are you closing Audacity?
Does the crash occur before or after the "Save Project" prompt?
Permanent link to this post Posted by tpx » Sun Apr 15, 2018 4:39 pm
lastest vs is 2.2.2, closing with the X on upper right corner, crashes after clicking No on the Save Project prompt
I noticed that crashes happen almost all the time with WAV files, none with FLAC or MP3
Ive attached the Media Info from the WAV file: nothing special about it, this is actually the decoded file from the same FLAC file which doesnt crash Audacity
tpx
Permanent link to this post Posted by tpx » Sun Apr 15, 2018 4:46 pm
in case ur wondering what FLAC en/decoder I use, see below. Try it yourself, decode a FLAC file, then edit it with (Open with) Audacity, do nothing but close (X upper right) repeat a few times if it doesnt crash at first, it will eventually then its almost every times
flac - Command-line FLAC encoder/decoder version 1.3.1
Copyright (C) 2000-2009 Josh Coalson
Copyright (C) 2011-2014 Xiph.Org Foundation
tpx
Permanent link to this post Posted by steve » Sun Apr 15, 2018 4:56 pm
In "Edit menu > Preferences > Import / Export", what are your settings?
Permanent link to this post Posted by tpx » Sun Apr 15, 2018 5:19 pm
there u go
tpx
Permanent link to this post Posted by steve » Sun Apr 15, 2018 5:21 pm
Try changing the first option ("When importing audio files") to "Copy uncompressed files into the project (safer)".
Permanent link to this post Posted by tpx » Sun Apr 15, 2018 5:25 pm
ok, the "Safer" method seems to not crash Audacity anymore, but the "Faster" is, and I bet it does on your system also
thanks for your time Steve
tpx
Permanent link to this post Posted by steve » Sun Apr 15, 2018 6:41 pm
Yes I can reproduce the crash in Audacity 2.2.2, but not in "debug" builds, which most of the developers use, (and is probably why this has not been spotted earlier).
I shall log this on the bug tracker, so hopefully it will be fixed in the next release.
Permanent link to this post Posted by tpx » Sun Apr 15, 2018 6:54 pm
good!
thanks again for your support Steve
tpx
Next
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 9 guests
