Plugin incompatibility
Permanent link to this post Posted by Piotr Grochowski » Sat Apr 14, 2018 5:28 am
The "Click Track" plugin I added to 2.1.3 now refuses to enable in 2.2.2. It does not give me any error — but it never appears on menu, and each time I come to Add / Remove Plug–ins... it is disabled.
Piotr Grochowski
Probationer
Re: Plugin incompatibility
Permanent link to this post Posted by steve » Sat Apr 14, 2018 9:50 am
Which "Click Track plug-in"?
Where can I get this plug-in?
Are you aware that Audacity 2.2.2 has a click-track plug-in by default? It's called "Rhythm Track" http://manual.audacityteam.org/man/rhythm_track.html
Permanent link to this post Posted by Piotr Grochowski » Sat Apr 14, 2018 10:34 am
I mean the plugin that used to exist on certain older Audacities. https://www.princeton.edu/~fanders/Auda ... cktrack.ny
The problem was not incompatibility, but that it was no longer in the folder for some reason. I remember adding it, back when I had 2.1.3.
Piotr Grochowski
Probationer
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 6 guests
