U-Law dithering
Re: U-Law dithering
Permanent link to this post Posted by Piotr Grochowski » Sun Apr 15, 2018 4:09 pm
steve wrote:
Piotr Grochowski wrote:However, it would still be nice to have a Preferences...
If you can show me an implementation of your proposed u-Law dither that works, then I'll suggest it to the developers.
I'm sorry, I'm not a programmer. However it should be possible to use if statements to detect the precision of the current sample, and multiply the dither by the appropriate amount depending on precision.
Piotr Grochowski
Probationer
Re: U-Law dithering
Permanent link to this post Posted by Piotr Grochowski » Sun Apr 15, 2018 4:10 pm
And isn't the statement "to the developers" redundant, as you are the main developer?
Piotr Grochowski
Probationer
Re: U-Law dithering
Permanent link to this post Posted by Piotr Grochowski » Sun Apr 15, 2018 4:15 pm
steve wrote:
Piotr Grochowski wrote:I don't know what causes the weird effect that two noises may suddenly seem similar volume when increased in volume by the same factor.
The "equal loudness curve" becomes flatter as the volume level increases (https://en.wikipedia.org/wiki/Equal-loudness_contour)
Exactly the "weird effect" I am talking about. Is it evolutionary or something? (the answer to this question does not belong in this forum; it belongs in some biology forum)
Piotr Grochowski
Probationer
Re: U-Law dithering
Permanent link to this post Posted by steve » Sun Apr 15, 2018 4:32 pm
Piotr Grochowski wrote:And isn't the statement "to the developers" redundant, as you are the main developer?
I'm not the main developer. I'm the forum administrator, and I do some development, some bug fixing, and some documentation.
Piotr Grochowski wrote:I'm sorry, I'm not a programmer.
It doesn't have to be code written by you. If you can show me an implementation of u-Law dither by anyone, that is implemented in the way that you describe, and works, then I'll bring it to the attention of the (other) developers. As far as I'm aware, no such implementation exists, because dithering as you propose does not give useful results, so unless you can show me otherwise, I'm done with this topic.
Re: U-Law dithering
Permanent link to this post Posted by Piotr Grochowski » Sun Apr 15, 2018 5:22 pm
This is your last straw. I'm sorry, I can't find any dithering implementation for U-law online. By the way; Rectangular dithering has also been tested with u-law, it did not work either. Rectangular dithering is supposed to add a random value between 0 and 0.9999999998 times the step size, and then round DOWN to a possible sample value, right? (similarly to no dithering, which adds 0.5 times the step size before rounding down)
Piotr Grochowski
Probationer
Previous
Return to Windows
Who is online
Users browsing this forum: No registered users and 6 guests
