Latency controls are not working.
Permanent link to this post Posted by pounder » Wed Apr 11, 2018 10:06 pm
(windows 10, audacity 2.2.2)
First thanks to anyone who takes the tome to try and help. The (track shift after record) function has no effect on the snap back position of the newly recorded track
pounder
Re: Latency controls are not working.
Permanent link to this post Posted by kozikowski » Thu Apr 12, 2018 2:47 am
I believe you don't get the alignment action if you don't have Overdub selected. Without the overdub setting, you're just ordinary multi-track recording without the timing correction.
Audacity > Edit > Preferences > Recording: [x] ..overdub.
This is fuzzier, but I think you also have to have [X] Always record on a new track.
If you do all that and it still doesn't work, deselect overdub > OK.
Restart Audacity. Open the panel again and select overdub > OK.
Let us know.
Permanent link to this post Posted by steve » Thu Apr 12, 2018 8:13 am
pounder wrote:The (track shift after record) function has no effect on the snap back position of the newly recorded track
There is no effect on the first track in the project, and that is intentional. The shift backwards is intended to bring new recorded tracks in synchronisation with other tracks in the project, so it only has any effect if there are other tracks in the project.
Permanent link to this post Posted by pounder » Sun Apr 15, 2018 2:20 am
Thanks. But That does go without saying. ;)
pounder
Permanent link to this post Posted by pounder » Sun Apr 15, 2018 2:24 am
kozikowski thank you I will try that right now
pounder
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 5 guests
