It wont play
Runnin a quad core W10 hp laptop @ 2.16Ghz And just downloaded V.2.2.2. I can record, i see the wave forms but it wont play. I can import files but they wont play. It just sits there. Any help would be appreciated.
Ensure that your sound card / audio device is working, and there are not other programs using it.
If you still have the problem, tell us more about what you are doing and what equipment you are using.
