Using Audacity 2.2.2 in Windows 10 and Windows 7, exactly the same result in both.
I cannot export to MP3. (or other formats)
I have installed Lame_v3.99.3_for_Windows on both Windows 10 & 7 systems.
Lame shows up in the Preferences/Libraries as MP3 export library, with the correct path & file name in both systems.
With current project open, I go to file-export; most options are greyed-out and unresponsive.
The only active options are “Export MIDI” or “Save compressed copy of Project”
Export MIDI seems to work as expected, and the resulting file can be opened OK.
What am I missing or forgetting?
Save Compressed Copy does not work properly; there is no “_data” folder, and the file cannot be opened.
(I don’t expect to use compression, so this probably will never affect me)
