Opening disclaimer: This is, admittedly, my first attempt at using Audacity with Windows 10. Prior to this, I’d been using Vista for the better part of the decade up until I was forced to change laptops last year. I’m just now getting back into using Audacity again.
Anyways…
So, I’m stuck in the position of I can’t get Audacity to record streaming audio and I have no idea why/what needs adjusting. Trying to look through the manual, the multiple different FAQs…honestly, I feel like I’m looking for the proverbial needle in the haystack here as to what’s wrong.
I go to check my available recording devices - as in, right-click my volume setting, click Recording devices, it’s the Recording tab on the window that pops up. Display Disabled/Disconnected Devices are both set to On. On that tab, shows just two Microphone devices. When even one of them is turned on, I can’t record anything meaningful, not even when the Audacity input device is set to Microsoft Sound Mapper - Input. I get a mostly-flat line with tiny dots along it, kind of like it wants to record external sound, not internal (playing) sound, but there’s no microphone plugged in to the jack.
When MME is my set Host, my only options are Microsoft Sound Mapper or any enabled Microphones. If I disable both Microphones in Windows, MME doesn’t let me choose an input device. Instead, I get “Error opening sound device”.
When Windows DirectSound is my set Host, it’s not much different. Input options are Primary Sound Capture Driver or enabled Microphones. No enabled Mics, no being able to choose an input device.
And choosing Windows WASAPI is more or less equivalent to spinning my wheels. Regardless of chosen input device, I click Record and the track opens and then it does nothing, like it’s not actually trying to record.
Changing my Playback device doesn’t change any of these.
Somewhere along the way, I read where it could be that my sound drivers need updating. I thought maybe that was a possibility, since my physical laptop is a Dell Inspiron 1525, which was released in 2008. I go to check the drivers - updated 2/21/2018. So the drivers being the issue doesn’t seem likely.
I’m evidently overlooking something but have no idea what. Can anyone help me narrow this down?
