I only want to delete a small duration of my voice.
Permanent link to this post Posted by audacityloverr » Mon Mar 19, 2018 3:54 am
`HI when i want to re do a part of a song I failled with my voice, i select the section to be redone and press delete but it also moves the rest of my voice back .
before if i remember well it was deleting the bad part but not moving the rest of the voice backward...
how to fix
tx
audacityloverr
Operating System: Windows 7
Re: I only want to delete a small duration of my voice.
Permanent link to this post Posted by kozikowski » Mon Mar 19, 2018 4:56 am
It's not delete.
Select the portion to be removed and Generate Silence. Audacity should automatically make a silent slug to fit in the hole.
Permanent link to this post Posted by waxcylinder » Mon Mar 19, 2018 12:42 pm
See this tutorial in the Audacity Manual: https://manual.audacityteam.org/man/tut ... dings.html
waxcylinder
Permanent link to this post Posted by audacityloverr » Fri Mar 23, 2018 1:27 am
tx
audacityloverr
Return to Windows
Who is online
Users browsing this forum: No registered users and 6 guests
