Hi
every time i open up the audacity date, this message pops up
has someone an idea ?
thanks
Mrlolplayer
Hi
thanks
Mrlolplayer
There are two parts to an Audacity project. There is the “project file” (which has the file extension “.aup”) and there is the audio data. The “project file” is a text file (XML format) that tells Audacity how to put the audio data together, but does NOT include any audio data itself. By default, the audio data is in a folder that has the same name as the project with “_data” appended. For example, if you save a project as “MyProject”, then the project file will be named “MyProject.aup” and the data folder will be named “MyProject_data”.
The project file and the _data folder MUST stay together and MUST NOT be edited manually.
For more information, see: http://manual.audacityteam.org/man/audacity_projects.html
