ChuckBarnett wrote:I don't think the peaks should be full frame?
ChuckBarnett wrote: I use Amazing Slow Downer to change key and perhaps speed
Yes. It's either clipped or severally limited.* You'd have to zoom-in to look at the peaks and you might have to reduce the level (the Amplify effect with a negative dB value) so you can see if the top of the wave if it goes over 0dB (1.0).Is this what clipping looks like?
There is a Clip Fix effect but its impossible to know the height & shape of the original waveform. So it's best if you can prevent it.How do I eliminate that?
Did you "look at" the waveform before running it through Amazing Slow Downer? That's probably not the cause, but it's worth checking.I use Amazing Slow Downer to change key and perhaps speed and then open that wav file with Audacity.
As you probably know, MP3 is lossy. The wave shape changes and some peaks get higher and some get lower. So it's not unusual for some new-peaks to go over 0dB (+1dB or so). It's not (necessarily) clipped because MP3 can go over 0dB without clipping, but Audacity will show red (probably abut half of the MP3s I've ripped from CD show red) and if you play it at "full digital volume", your digital-to-analog converter will clip. I've never heard of a case where this clipping was audible, but some people like to normalize to about -1dB before making an MP3.Most of my use of Audacity is to convert files from wav to mp3.
Users browsing this forum: Google [Bot], Rory G. Rojas and 8 guests
