Plugin not showing up
and the exact three-section version of Audacity from "Help menu > About Audacity".
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
Permanent link to this post Posted by glennzweig » Thu Mar 08, 2018 1:14 am
I'm trying to download the noisegate plugin. I copied it into the plugin file and then enabled it under add/remove in audacity. I then reopened the app. But noisegate is not showing up under effects.
Operating System: Windows 7
Return to Windows
Who is online
Users browsing this forum: No registered users and 19 guests
