Locking a single audio file into position
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Trainer » Wed Jan 24, 2018 4:02 am
Hi. Not sure if this has been asked before.
When creating 5 minute radio programmes, I like to place a piece of outro music so that it ends exactly at the 5 minute mark. Then I make all the other audio components fit in before that.
Sometimes I accidentally move it, which is a bit annoying.
Is there any way to lock a single audio file in position, so I can't move it? I know there is the sync lock function, which locks multiple files together. but I want to be able to safely move the other files around individually, while my outro music stays in position.
Thank you for your help.
Return to Windows
Who is online
Users browsing this forum: No registered users and 9 guests
