High
I tried to use the de Reverberate LE convoluton reverb plug-in version in Audicity 2.1.
It was for free buth only availiable in 32 bits and it did not work properly. I upgrade Audicity
to version 2.2. In this version it did not work at all
In the latest Computer Music magazine I found a 64 bit version of this plug-in.
Although it shows 2 versions (32 and 64 bit) the 64 bit version is also installed in program (x64).
The dll file is installed in the plug-in the folder of audicity.
I switch the new plug-in on but do not see it in the list of activated plug-ins.
What cann be the cause??
I have removed the complete instalation of both applications including app-data, without succes
Who cann help
Regards
Peter
