2.2.1 on Windows 10
I’m having trouble loading a plug in. I’m using the plug in add / delete at the top of the list and click New. It shows the plug in I want to install so I click Enable then OK. Audacity shows it running a script to install the plug in but that’s it. When I go into analyze I don’t find any of the attributes that should have loaded. Am I doing this wrong or is there a bug in 2.2.1?
John
What plug-in?
Vamp 1.7 because 1.7.1 doesn’t work, I heard.
John
