Slow work.
and the exact three-section version of Audacity from "Help menu > About Audacity".
Slow work.
Permanent link to this post Posted by юра00 » Wed Jan 03, 2018 7:38 am
Dear specialists! Thank you and Happy New Year. But I write on the issue that Audacity has started to work more slowly. This applies to all effects and import/export. System reinstalled, errors are excluded. Problems started somewhere in December, I do not remember exactly. Please, check and fix it. Audacity 2.2.1. Windows 10 build 1709. Thank you!
юра00
Re: Slow work.
Permanent link to this post Posted by юра00 » Wed Jan 03, 2018 7:43 am
For example, the import of a file of 4 minutes in length takes 6 seconds. The effect "Change speed" is 12 seconds. And so all others, built-in and Nyquist plugins. This is much slower than before, which makes the job less convenient.
юра00
Re: Slow work.
Permanent link to this post Posted by steve » Wed Jan 03, 2018 8:56 am
юра00 wrote:I write on the issue that Audacity has started to work more slowly.
What has changed since Audacity was working more quickly?
Re: Slow work.
Permanent link to this post Posted by юра00 » Wed Jan 03, 2018 11:54 am
The fact of the matter is that there are no apparent reasons. In my opinion, after moving to Audacity 2.2.1 Is it just me? I think a problem that concerns many. In complete confusion. Maybe the laptop is new, somehow connected with this. Did you check on Windows 10? How much, for example, does the export last?
юра00
Re: Slow work.
Permanent link to this post Posted by kozikowski » Wed Jan 03, 2018 2:02 pm
Have you started using Cloud Services? You may find that those like to do heavy processing in the background and not tell you.
Do you have a browser running? It's not unusual for FireFox to slowly fill up your machine with client services. Firefox 50%, Firefox Web Services 125%.
New machines are a lot busier than they used to be.
Re: Slow work.
Permanent link to this post Posted by kozikowski » Wed Jan 03, 2018 2:05 pm
There is one problem that's been cropping up more and more. Audacity will work well for the first ten or twelve seconds and then go nuts. I don't know anybody's ever figured out what's doing that, but if you have a borderline machine, it will just stop working.
Re: Slow work.
Permanent link to this post Posted by юра00 » Fri Jan 05, 2018 9:22 am
I'll check on another machine through several days. Please, don't close the topic.
юра00
Re: Slow work.
Permanent link to this post Posted by waxcylinder » Mon Jan 08, 2018 10:12 am
I regularly test on various different versions of Audacity on my W10 laptop (and an my Macbook Pro) and I haven't noticed any slowdown - so i conducted some timing tests on the functions you particularly mentione on 2.1.3, 2.2.0, 2.1.1 and the alpha 2.2.2.
For the test I created a one hour WAV, one hour MP3 and open hour AAC files
For Import (all done by drag & drop) of Mp3 and AAC there was no measurable difference between the Audacity versions, taking 17-19 seconds. I also tested Amplify changing speed from 33 1/3 to 45 and tested Amplify - once again no discernible difference.
However it looks as though there may have been a problem with 2.2.0 and 2.2.1. For 2.1.3 the one-hour WAV takes just 7 seconds to import, whereas for 2.2.0 and 2.2.3 this increases to 21-24 seconds. But on the upcoming 2.2.2 the alpha version has gone back to importing at 7 seconds again.
One of the developers was working on drag&drop recently (but experimenting for effects rather than audio imports) and for a while this introduced a (very noticeable) delay before audio imports - but he fixed that. It is possible that that fix dealt with the anomaly that crept in after 2.1.3.
waxcylinder
Re: Slow work.
Permanent link to this post Posted by юра00 » Mon Jan 08, 2018 11:04 am
While I have a version that for different brands of computers the speed can be different. But this must be checked. Very slowly there is an export to mp3.
юра00
Re: Slow work.
Permanent link to this post Posted by waxcylinder » Tue Jan 09, 2018 12:03 pm
юра00 wrote:While I have a version that for different brands of computers the speed can be different. But this must be checked. Very slowly there is an export to mp3.
As I pointed out in my precious post , when testing on my W10 laptop I van measure no discernible difference in MP3 export times of a one-hour project on 2/1/3, 2.2.0, 2.2.1 or the latest alpha for the upcoming 2.2.2.
All take the same 17-18 seconds
MP3 exports of the same audio are also consistent across the versions at 17-18 seconds.
waxcylinder
Next
Return to Windows
Who is online
Users browsing this forum: Yahoo [Bot] and 7 guests
