WAS File Issue
and the exact three-section version of Audacity from "Help menu > About Audacity".
WAS File Issue
Permanent link to this post Posted by paddynski » Tue Jan 02, 2018 3:19 pm
Hi
I am trying to convert an MP# to a WAV file that will work on Windows 3.11.
I have tried a lot of things with no success.
Can any of you help?
All the best
Patrick
paddynski
Re: WAS File Issue
Permanent link to this post Posted by steve » Tue Jan 02, 2018 4:35 pm
"WAS File Issue"
I'm guessing that should be "WAV file issue"?
paddynski wrote:I am trying to convert an MP# to a WAV file that will work on Windows 3.11.
You mean "MP3 to WAV"?
Do you mean that you want the WAV file to work on Windows 3.11, or that you want the converter to run on Windows 3.11?
Audacity does not run on Windows 3.11.
Any standard 16-bit mono or stereo WAV file should work on Windows 3.11.
There are a number of on-line audio format converts that can convert from MP3 to WAV. Just try a Google search for "free audio format converter".
Re: WAS File Issue
Permanent link to this post Posted by DVDdoug » Tue Jan 02, 2018 5:35 pm
Can you play any WAV files? Does the old computer have a working soundcard & driver, and some kind of player software? (Those older computers always had a speaker that could "beep", but a soundcard was optional.)
Such as? How far did you get? Did you make a WAV file that plays on your modern computer?
You should be able to open the MP3 in Audacity and Export as WAV.
DVDdoug
Forum Crew
Return to Windows
Who is online
Users browsing this forum: Yahoo [Bot] and 6 guests
