Recording stops after 5-10 seconds
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by LSKN » Mon Jan 01, 2018 3:56 pm
I am using Audacity 2.2.1 on a Win 10 laptop with a Samson GoMic (USB mic)
I recently set up a new laptop and after installing Audacity and the mic, it stops recording after 10 seconds or so (sometimes less). I read through some threads on this forum and have made sure that I don't have timed recording set and the "snap to" is off. I also don't have sound-activated recording on. I am using MME with a project rate of 44100. I also tried uninstalling and re-installing Audacity.
I've used Audacity on an older laptop (also Win 10) many times with the same mic and didn't have this issue.
Thanks for any help you can provide.
LSKN
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
