cannot get sound with 4-usb audio codec
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by henrycooper » Mon Jan 01, 2018 3:02 pm
Until three days ago I worked successfully with Audacity 2.1.3 When I looked at the recording devices available I saw 3-USB audio codec and chose it.
Today I came to use the same Audacity 2.1.3. The 3-USB audio codec was no longer shown; instead I saw 4-USB audio codec. When I looked at recording devices, sure enough 3-usb had gone and 4-usb was there in its place. When I try to record with 4-usb audio codec I get no signal.
I installed Audacity 2.2.1 but encountered the same problem.
Why does 4-usb not work for me?
How can I get back to 3-usb which did work?
I have found that the Realtek codec gives bad results, a booming bathroom echo in the bass. Why is this?
henrycooper
Re: cannot get sound with 4-usb audio codec
Permanent link to this post Posted by Trebor » Mon Jan 01, 2018 5:15 pm
henrycooper wrote: The 3-USB audio codec was no longer shown ... How can I get back to 3-usb which did work?
In Windows, disconnected & disabled recording-devices can be hidden. Here's how to make them visible ...
http://www.thewindowsclub.com/how-to-enable-all-recording-devices-in-windows
Trebor
Permanent link to this post Posted by henrycooper » Mon Jan 01, 2018 9:35 pm
fields of Athenry B.mp3
with Realtek
(362.89 KiB) Downloaded 2 times
I already have all disabled and disconnected devices shown. The issue is that when I select recording device as 4-usb audio codec I get no signal whereas when I select recording device as Realtek high definition I do get a signal, albeit one with booming bass. So .. the questions are really these three:
how can I get good quality from the Realtek codec? I cannot believe I am getting the best out of it.
why do I get no sound from the 4-usb codec?
how can I reinstall the 3-usb codec that worked before?
I am attaching three files with notes as to history
Scots wha ha'e 1 S.mp3
with 3-usb
(471.85 KiB) Downloaded 2 times
F of A v1 D.mp3
with 3-usb
(1.08 MiB) Downloaded 3 times
henrycooper
Permanent link to this post Posted by henrycooper » Tue Jan 02, 2018 12:37 pm
I did show disabled and disconnected codecs but no usb was shown
henrycooper
Permanent link to this post Posted by Trebor » Thu Jan 04, 2018 2:50 pm
"fields of Athenry B.mp3" has been distorted by real-time noise-reduction, (that's not Audacity's fault).
You can switch-off that noise-reduction, (aka noise-suppression), "enhancement" in Windows recording devices ...
Disable (untick) all the enhancements/effects you find in the properties of your recording-device if you want to record a musical performance.
Trebor
Return to Windows
Who is online
Users browsing this forum: No registered users and 6 guests
