how do i do this with audicity
Permanent link to this post Posted by benbernie » Mon Jan 01, 2018 1:36 am
hi
I have this 78 that has a skip in the middle of it..its not a skip that keeps repeating itself..its a skip that happens once and then the tonearm
keeps going..is there a way to remove the skip with audacity??
lenny
benbernie
Re: how do i do this with audicity
Permanent link to this post Posted by Trebor » Mon Jan 01, 2018 4:09 am
Envelope tool could be used to reduce the volume of the skip , (and does not effect timing) ...
Could select the skip noise, then delete it, but that could muck-up the timing of the music.
Trebor
Permanent link to this post Posted by waxcylinder » Thu Jan 04, 2018 3:46 pm
How big is the skip (number of samples)?
If it's small enough (less tan 128 samples) you could use Effect>Repair
If it's longer you can try the Draw tool (in the Tools toolbar) to redraw the waveform manually.
See this tutorial in the Audacity ManualL https://manual.audacityteam.org/man/tut ... iques.html
waxcylinder
Permanent link to this post Posted by DVDdoug » Thu Jan 04, 2018 5:10 pm
If the record is literally skipping ahead by one or more grooves, have you tried increasing the tracking force or playing with the anti-skate adjustment (if your turntable has an anti-skate adjustment)?
If you upload/attach a short sample with the skip in the middle, we can play with it. If it's actually skipping-ahead a longer sample would be better so we can get the "context". (A longer sample would have to be MP3 or other compressed format, due to size limits.)
keeps going..
If the record skips-ahead we call that a "skip" and if it skips-back we say the record is "stuck".
DVDdoug
Forum Crew
Return to Windows
Who is online
Users browsing this forum: No registered users and 6 guests
