My Audacity folder is empty
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Chloe03 » Sun Dec 31, 2017 6:45 pm
Hi everyone, I hope this hasn't been addressed before, I looked quickly but couldn't find the answer to my question. I want to install a plug-in, but my Audacity folder is totally empty, I don't have that "plug-in" folder in which I should put my plug-in file. Can somebody help me? I tried to check "show hidden folders" on my computer but it didn't work.
Thank you.
Chloe03
Re: My Audacity folder is empty
Permanent link to this post Posted by steve » Sun Dec 31, 2017 7:00 pm
Windows 10?
Which version of Audacity?
How did you install Audacity?
Permanent link to this post Posted by Chloe03 » Tue Jan 02, 2018 1:54 am
Hi. Thanks for your answer. I have Windows 10 and I have the 2.1.3 version. I downloaded it from the Audacity's website.
Chloe03
Permanent link to this post Posted by steve » Wed Jan 03, 2018 3:59 pm
steve wrote:How did you install Audacity?
Did you download and run the EXE installer from here: https://www.audacityteam.org/download/windows/
Have you tried running Audacity? Does it run?
Chloe03 wrote:my Audacity folder is totally empty
Which folder precisely are you referring to? What is the full path name?
Permanent link to this post Posted by Chloe03 » Wed Jan 03, 2018 7:37 pm
Yes, that's what I did. It runs perfectly well, I did some recordings already.
I downloaded it in French, maybe that's the problem? The path in English should be something like this : My computer/Documents/Audacity
Chloe03
Permanent link to this post Posted by steve » Thu Jan 04, 2018 10:00 am
Chloe03 wrote:The path in English should be something like this : My computer/Documents/Audacity
That is a path suitable for saving your work, but it is not the correct location for installing plug-ins.
For installing Nyquist plug-ins, put them in:
/Users/<user name>/AppData\Roaming/audacity\Plug-Ins/
where "<user name>" is your computer log-in name.
Note that "/Users/<user name>/AppData" is a hidden folder.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], ploxauda, sarel93 and 7 guests
