recording a converstion
Permanent link to this post Posted by estee11 » Sat Dec 30, 2017 4:03 pm
sorry for my ignorance:
when i record a talk with a person or with couple - some speak loudly and others softly. how do i normalize?
if i mark for instance -10 the softer almost disappears.
i would like to bring it all to more or less same level.
thanks,
estee
estee11
Re: recording a converstion
Permanent link to this post Posted by Trebor » Sat Dec 30, 2017 5:08 pm
estee11 wrote: when i record a talk with a person or with couple - some speak loudly and others softly. how do i normalize? ...
There's an Audacity plugin for that : LevelSpeech2.ny
[ How to install plugin ...http://wiki.audacityteam.org/wiki/Download_Nyquist_Plug-ins#install ].
Trebor
Permanent link to this post Posted by DVDdoug » Sat Dec 30, 2017 5:20 pm
You can use the Envelope Tool to adjust the volume up & down manually. (The idea is to "fade" the volume up & down and try to avoid sudden jumps.)
The Compressor & Limiter effects can help (use make-up gain with either effect). There is also a Leveller setting under the Distortion effect.
Note that any of these adjustments will also adjust the background noise, and that can be distracting.
how do i normalize?
FYI - The Normalize effect doesn't do that. Normalization adjusts the volume of the whole file by the same amount (like setting the volume control once before you start playback), setting the peaks to a particular target amplitude (typically the 0dB maximum).
DVDdoug
Forum Crew
Permanent link to this post Posted by estee11 » Sun Dec 31, 2017 7:39 am
hi
thanks for your answers.
1. is there guide lines about "ideal" volume"?
2. is there a function of lowering like there is Amplify?
3. it would be helpful to know (i'm a novice) what to do with peaks in talk
thanks!!
estee
estee11
Permanent link to this post Posted by Trebor » Sun Dec 31, 2017 12:27 pm
estee11 wrote:2. is there a function of lowering like there is Amplify?
If you put a negative number into "Amplify" it will reduce the volume, e.g. ...
negative amplify.gif (98.56 KiB) Viewed 155 times
estee11 wrote:3. it would be helpful to know (i'm a novice) what to do with peaks in talk
Audacity's (soft) limiter, (with no make-up gain), will reduce volume of loud talk only, as will a compressor, ( again select no make-up gain ).
Trebor
Permanent link to this post Posted by estee11 » Sun Dec 31, 2017 7:05 pm
great video.
GOT IT!
thank you so much
estee
estee11
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 9 guests
