Error after editing.
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by bodegg » Thu Dec 28, 2017 5:26 pm
On xmas eve I recorded a broadcast on local radio to listen to later on that evening. When I came to playing it back I thought I would trim the first 15 mins or so as that was just news and adverts. I selected the part and deleted it. Then I thought I would save the resultant project in case I didn't get chance to listen to it all. When I attempted to save it as a project I got this error message:-
I think I chose the last option at first. Now I get this every time I open the project and I have missing audio for a few seconds. Not only that I can't export the project in any other format. I get this message instead:-
Although I can't save or repair the file, I can listen to what remains, so all's not completely lost. However this has never happened to me before and I've used audacity many times to create my own multitrack recordings. I'm now somewhat reluctant to even open any personal projects in case I lose important data. This occurred after I had updated to 2.2.1.
Any ideas? How safe is it to use?
bodegg
Operating System: Windows 7
Re: Error after editing.
Permanent link to this post Posted by DVDdoug » Thu Dec 28, 2017 6:58 pm
It's a computer!!! Once in awhile you're going to have a problem... :cry:
Simply opening (reading the files) shouldn't hurt anything but make a back-up* before you open it.
In the future, I recommend exporting to WAV (or FLAC, etc.) as a back-up immediately after recording. A regular audio file is a single-file so it's easier to move-around a harder to corrupt/screw-up. (Of course it depends on what you're doing but I rarely make an AUP project, I mostly just export audio files.)
And of course if it's super-critical, make multiple back-ups and store in multiple locations, etc.
If you're recording something critical and there's no possibility of "take two", I recommend two recorders running in parallel (and a UPS or battery-powered laptop).
* Don't just back-up the AUP file, make sure to back-up the whole project/folder.
DVDdoug
Forum Crew
Permanent link to this post Posted by bodegg » Fri Dec 29, 2017 6:38 pm
Hmmm... so basically I can reduce your reply to two words: "S**t happens"? :roll: Anyway I have just tried it again, same procedure, and got the same result. Latest build, windows 7. If anyone else wants to try and replicate this here's what I did.
Recorded a couple of minutes audio from an online radio player.
Saved file as aup. Closed program.
Reopened file with audacity - no problem.
Selected a chunk of audio from beginning, approx 30 secs, and deleted.
Reopened file and got the same result and error message as above image 1.
This time got new error message after choosing action:-
audacity error.jpg (98.01 KiB) Viewed 188 times
Still can't export file in any other format.
Can't save as aup either. Saying location is not writable or disk is full!
I may have the previous version of audacity somewhere else so I can do more tests, but until then I'm not using this version on my own projects. I do rely on the aup format for multitrack recording and editing, so it's very important to me! And yes I do make backups as would anyone using this software for music production.
bodegg
Permanent link to this post Posted by fwm » Fri Dec 29, 2017 7:24 pm
I reported a similar fault with 2.2.1, using Vista, about a week back - lots of emails to/fro up to Xmas day: await the 'fix'....
Same result on another Vista laptop.
It arose by saving the aup project (a second time) into the existing name, with every edit leaving a destroyed data file (dialog box as in your screenshots).
The solution seems (tho' have gone back to 2.1.3) to rename the 2nd project with a different name and again for each subsequent save.
As it apparently affects more than Vista this seems a major bug; with no site notification..!
fwm
Permanent link to this post Posted by steve » Fri Dec 29, 2017 8:06 pm
bodegg wrote:Recorded a couple of minutes audio from an online radio player.
I've tried following those steps multiple times and I'm not able to reproduce the problem. Each time I open the project I get exactly the project that I'm expecting, and no errors.
Where exactly are you saving the project and what file name are you using?
Please try running a full virus scan on your computer - the problem may not be caused by a virus (although that's not impossible), it could be that your virus checker is suspicious of Audacity and interfering with Audacity's normal operation - if that's the problem, then a full scan is likely to throw up some false positives.
fwm wrote:I reported a similar fault with 2.2.1,
Similar, but different, so if you wish to discuss that on this forum it would be better to start a new topic.
Permanent link to this post Posted by bodegg » Sat Dec 30, 2017 9:14 am
This morning I have used a different pc with V2.1.3 installed and was unable to replicate the problem - all normal. Whilst doing this I ran a virus scan on the 'updated' pc and no results were found. I uninstalled the latest version and installed this older version instead. Once again I couldn't replicate the problem that I had with the latest build. I tried to open the damaged files but still got the same error messages and was still unable to export in any format, so I guess I can't repair those. For now I'm going to stick with the older version which I haven't had any issues with.
bodegg
Permanent link to this post Posted by steve » Sat Dec 30, 2017 11:09 am
bodegg wrote:For now I'm going to stick with the older version which I haven't had any issues with.
I think that's the best idea for your work, but it would be helpful if you could also help us to try to discover what the problem is with 2.2.1. Would you be willing to help with that?
Permanent link to this post Posted by bodegg » Sat Dec 30, 2017 11:31 am
Yes I'll try and help the best I can but I'm not too software savvy, in fact it doesn't usually take much of a software issue to beat me! I did notice that on one error message there is a 'show log' icon. Would that be of any use?
bodegg
Permanent link to this post Posted by steve » Sat Dec 30, 2017 1:46 pm
bodegg wrote:there is a 'show log' icon.
The log will probably just list the file names of the missing / orphan files.
I've asked the developers if there are any specific tests that you could do to help isolate the problem. I will write back here if there is anything.
If you've not done so already, you could click the "Subscribe topic" link at the bottom of this page so that you will be emailed when there are new posts to this topic.
Thanks for offering to help - much appreciated.
Permanent link to this post Posted by bodegg » Sat Dec 30, 2017 3:19 pm
I myself work in engineering maintenance and when I get a fault reported to me I like to gather as much info as possible and from varying sources. With that in mind, here's a snapshot of the fault log. Every little helps as they say!
I'm hoping that it's just pilot error and not a program error. As I say, I'm not a software or PC wiz by any means.
bodegg
Next
Return to Windows
Who is online
Users browsing this forum: chris galbraith, DVDdoug and 8 guests
