Problems Multitrack-Recording
Permanent link to this post Posted by Berg » Thu Dec 28, 2017 4:23 pm
Hey!
I am using Windows 10 and Audacity 2.2.1.
I have Steinberg Ur 12 Soundcard.
I have a problem when I try to record more than 1 track.
The problem is that when I record the second track the half of the sound from the first track is put in the second track.
For example I record first acoustic guitar in the first track and then I want to record only vocals in the second track.
The problem is that on the second track the sound from track 1 is being recorded, I want for example only vocals in the second track.
Hope you understand me, my english is not the best.
Best wishes
Berg
Re: Problems Multitrack-Recording
Permanent link to this post Posted by DVDdoug » Thu Dec 28, 2017 7:04 pm
Select your USB interface as your Recording Device and it will only record what's coming-out of your interface. (Do not select select "loopback" or "Stereo Mix".)
DVDdoug
Forum Crew
Permanent link to this post Posted by Berg » Fri Dec 29, 2017 7:13 am
I have done that but there is still the same problem.
Berg
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 13 guests
