Help to clean this Audio
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by hemalatha » Wed Dec 27, 2017 12:41 pm
Im a newbie using Audacity, and I require help cleaning this audio:
https://drive.google.com/file/d/14AiGWq ... sp=sharing
It seems very distorted, and I'm having trouble understanding which option to select to clean this audio.
Any suggestions will be appreciated. Thanks!
OS Used: Windows 10
Audacity: Version 2.2.2
hemalatha
Re: Help to clean this Audio
Permanent link to this post Posted by Trebor » Wed Dec 27, 2017 3:32 pm
hemalatha wrote:https://drive.google.com/file/d/14AiGWqv6JWHCF0ALsbh2RBHoUDD6ew6h/view?usp=sharing
A fault called called clipping has occurred when the volume was too loud, which is an incurable distortion.
If you sacrifice some of the highest frequencies using the equalizer it can be made less harsh, but no cure.
Trebor
Permanent link to this post Posted by hemalatha » Wed Jan 03, 2018 3:15 pm
Okay, I get it now...Thank you for the reply....
If not audacity, is there any other software I can use, to clean up this audio??
hemalatha
Permanent link to this post Posted by steve » Wed Jan 03, 2018 4:23 pm
Clipped audio is incurable. The overload has caused the tops and bottoms of the waveform to be destroyed. You can't get back from "destroyed".
Return to Windows
Who is online
Users browsing this forum: Google [Bot] and 10 guests
