audacity problem high cpu use (100%)
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by KAKOS » Wed Dec 06, 2017 2:07 pm
Hello ..
First of all i apologise for my english..
I have one problem with audacity..Almost everytime i export a wav song..from a wav Mix(1 hour) and i cut a part of it
when i open the folder which contains files from audacity (Cut) i see a green line on the top of the folder means that my cpu cant read the type of song..And then cpu goes full and i cant delete the song and i have to restart laptop..IF i restart and open the folder again this happens again..
Can some1 helps me what to do for fix this problem?
System windows 7 64bit,intel i7
KAKOS
Operating System: Windows 7
Re: audacity problem high cpu use (100%)
Permanent link to this post Posted by steve » Wed Dec 06, 2017 3:19 pm
Does this happen only with Audacity 2.2.1 RC2, or does it also happen with Audacity 2.2.0?
(Please also read the pink panel at the top of the page)
Permanent link to this post Posted by KAKOS » Wed Dec 06, 2017 4:35 pm
i use the version 2.2.0 i think is the last version..i dont use rc2
i will search the other answers..but if you know something please tell me..!
KAKOS
Permanent link to this post Posted by steve » Wed Dec 06, 2017 4:40 pm
Topic moved to the Windows forum.
KAKOS wrote:when i open the folder which contains files from audacity (Cut) i see a green line on the top of the folder means that my cpu cant read the type of song
Please post a screenshot to show what you mean.
See here for how to attach files to forum posts: viewtopic.php?f=49&t=64936
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 13 guests
