Lost audio end part when converting from Mono to Stereo
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by nckhrs » Mon Dec 04, 2017 5:06 pm
Hi,
I work with several mono WAV files, they are pretty long (2 - 3 hours). They have stereo channel (L and R track), however, the audio is only on the left channel.
I want to make the audio to play on both L and R channel, and here is what I did:
1. Split Stereo Track.
2. Select the whole left channel.
3. Paste it into the right channel.
4. Export Audio (into a new WAV file).
Everything looked fine on Audacity, I got full length audio on both L and R (approximately 2 hour and 30 min).
However, when I tried to play it using WMP, it showed that the file is only 1 hour and 42 min long. :o
So, I opened it using Audacity, to my surprise, the audio only appear up to 1 hour 42 min. The rest are blank (on both channels). :(
Anybody experience similar problem?
Did I do something wrong?
I really appreciate your help. :)
nckhrs
Re: Lost audio end part when converting from Mono to Stereo
Permanent link to this post Posted by steve » Mon Dec 04, 2017 5:32 pm
I'm not sure what went wrong, but there's a much easier way to make a single channel stereo recording play through both L and R channels:
1) Split to Mono
2) Delete the empty track (click on the [X] in the top left corner of the track.
That's all. it will play through both L and R channels.
When exported, it will create a mono track that plays through L and R channels.
Permanent link to this post Posted by nckhrs » Mon Dec 04, 2017 6:13 pm
steve wrote:I'm not sure what went wrong, but there's a much easier way to make a single channel stereo recording play through both L and R channels:
1) Split to Mono
Thanks a lot Steve, I will give it a shot. :)
Btw, just out of curiosity, it looks like it may be related to 4GB limitation.
Original file is 3GB (left only), and it became 6GB after I copy pasted the audio to the right channel.
Now... 1h 42m is approximately 2/3 of 2h 30m, which correlate with the size (4GB is 2/3 of 6GB).
Could it be related? Once again... this is just my curiosity.
nckhrs
Permanent link to this post Posted by kozikowski » Mon Dec 04, 2017 6:35 pm
The unconditional WAV file limit is 2Gb which works out to stereo 3 hours. Some systems can deal with 4Gb. Nobody can deal with 6Gb. You can get away with nose-bleed high quality MP3 or some of the other formats.
Permanent link to this post Posted by steve » Mon Dec 04, 2017 7:27 pm
kozikowski wrote:Some systems can deal with 4Gb
Are there any computers of the last 20 years that don't?
I've not seen the problem occur below 4GB in the last decade.
For a standard WAV file, the 4GB limit is absolute - data beyond 4GB cannot be accessed. Very often, exceeding 4GB will corrupt the file.
Permanent link to this post Posted by DVDdoug » Mon Dec 04, 2017 7:34 pm
Yup! Twice the uncompressed data.
If you actually have a 6GB file you should be able to open it in Audacity as Raw data. Then export in a different format or in a different resolution. (It's the 32-bit file-size field in the WAV header that has overflowed and reporting the wrong size.)
FYI - "CD quality" (44.1kHz, 16-bit, stereo) is about 10MB per minute.
DVDdoug
Forum Crew
Permanent link to this post Posted by nckhrs » Mon Dec 04, 2017 8:31 pm
Thanks Steve, I didn't know WAV file has 4GB hard limit.
nckhrs
Permanent link to this post Posted by nckhrs » Mon Dec 04, 2017 8:41 pm
That's the thing. It would work if the original file is 6GB. (Btw, but what are other raw formats that don't have 32-bit file-size limitation? :?: )
However, my original file is 3GB, and then after I worked on it, it became 6GB (still looked OK in Audacity), saved it, and then it got corrupted (because of WAV 4GB limit). Yep... supposedly after I worked on it, I need to export it to other format (MP3 for example) to avoid saving 6GB WAV file.
Note: I will try and stick Steve's suggestion to save it as Mono (smaller size) for practical reason.
Thanks a lot! :)
nckhrs
Permanent link to this post Posted by DVDdoug » Mon Dec 04, 2017 10:45 pm
No, 6GB is not a valid WAV file.
Almost any other format. RAW PCM data generally terrible because you (or the application) has to know the sample-rate, bit-depth, number of channels, the endian, and a couple of other details that are normally specified in the audio file header and read automatically by the application. You can use raw audio data in a "contained" application such as a game or a automated telephone system where there's only one format and one application and the application knows the format in advance.
What format do you want and/or what are you going to do with the file? I assume you are currently using "high resolution" (greater than 44.1kHz and/or greater than 16-bits)? There's probably no reason for that since CD quality is better than human hearing.
FLAC is lossless compression, there is no file-size limit, and the files are about half the size of WAV. MP3 is lossy compression, but at higher bitrates it often sounds identical to the uncompressed original (in a proper blind listening test). A good quality MP3 is about 1/5th the size of a CD quality file and if you start with high-resolution it might be 1/10 the size, or smaller.
P.S
I didn't read carefully before and I'm confused about something -
A stereo WAV file with one silent channel is the same size as if there is sound in both channels. In WAV file, silence takes-up just as much space as non-silence. (A regular 1-channel mono file is half the size.) So... Something else was changed... Maybe you increased the bit-depth?
DVDdoug
Forum Crew
Permanent link to this post Posted by nckhrs » Tue Dec 05, 2017 2:49 am
DVDdoug wrote:P.S
Thank you for such wealth of info.
Hmmm... that's quite interesting with the size thing. I didn't change anything.
I just opened the file with Audacity, and it shows the stereo track with only the signal/audio on the left channel, and it also says 32-bit float.
So... I'm not sure either how the size double when I copy paste the left to right. Did I do something wrong during my copy paste operation?
nckhrs
Next
Return to Windows
Who is online
Users browsing this forum: No registered users and 28 guests
