Help with recording from USB Turntable
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by scrogs » Sun Dec 03, 2017 5:12 am
I'm using windows 8.1 and have audacity 2.2.0.
When I record from the turntable, the pause button on the control toolbar is jumping in and out giving very stilted results with recording and on playback. This also happen when I tried using a USB mic. Can anyone help with this issue.
Thanks
Graeme
scrogs
Re: Help with recording from USB Turntable
Permanent link to this post Posted by DVDdoug » Sun Dec 03, 2017 8:31 pm
That's weird! The pausing during playback is especially weird!
Did you select the USB turntable as your Recording Device? (WASAPI Loopback can sometimes "act like" sound activated recording, but loopback is normally only be used for recording streaming/internet audio.)
And make sure that Sound Activated Recording is turned off (but it's unlikely that it was turned-on by accident).
DVDdoug
Forum Crew
Permanent link to this post Posted by scrogs » Mon Dec 04, 2017 12:29 am
Thanks doug, your suggestion worked fine. Cheers graeme
scrogs
Return to Windows
Who is online
Users browsing this forum: No registered users and 20 guests
