Separate voice from song?
and the exact three-section version of Audacity from "Help menu > About Audacity".
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
Permanent link to this post Posted by toneman » Sat Dec 02, 2017 9:50 pm
Hello. I have Audacity 2.1.0. I just downloaded it. I found the "Vocal Remover" tool under effects which removes the vocals from songs and leaves the song itself, but I can't find any effect to do the opposite, remove the song and leave the vocals. How do I do this? Or maybe separating the vocals from the song and having them in two files would work; like keeping the vocals separate from the song instead of just deleting the vocals like "Vocal Remover" does.
Operating System: Windows 7
Re: Separate voice from song?
Permanent link to this post Posted by kozikowski » Sun Dec 03, 2017 1:36 am
In Audacity 2.2.0 available here:
There is Effect > Vocal Reduction and Isolation.
Try it before you tell your client you can do this. There's a long list of ways this can fail. It's usually best if you go in assuming it's not going to work. ... ation.html
For example, if you have a mono show (one blue wave), that's the end of the story. It doesn't work at all in Mono.
A cousin to this is having a stereo show (two blue waves) but the waves are the same. That doesn't work, either.
And etc.
Return to Windows
Who is online
Users browsing this forum: Merowinger and 15 guests
