New version does not automatcally scroll left and/or right
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by swbeck » Sat Dec 02, 2017 4:25 pm
I bought a new laptop and had to download the current version of Audacity (2.2.0) This laptop has Windows 10. On the old version of Audacity, when I wanted to select big portion of an audio file, I could click on where I wanted to start and then hold the mouse down and when I hit the end of the window, it would automatically scroll the audio file that direction until I released the mouse. The new version does not do this. Is there some setting that has changed that I can set to do this. It takes much longer to edit an audio file when you can only select what is in the window displayed.
Thanks,
Stan
swbeck
Re: New version does not automatcally scroll left and/or rig
Permanent link to this post Posted by Trebor » Sun Dec 03, 2017 11:02 am
swbeck wrote: On the old version of Audacity, when I wanted to select big portion of an audio file, I could click on where I wanted to start and then hold the mouse down and when I hit the end of the window ...
You have to hold down the "Ctrl" key whilst using the scroll-wheel on the mouse to zoom in/out.
Alternatively use the zoom tool
Trebor
Permanent link to this post Posted by steve » Sun Dec 03, 2017 1:10 pm
swbeck wrote:The new version does not do this. Is there some setting that has changed that I can set to do this.
It's a bug in Audacity 2.2.0. It has now been fixed, and the fixed version is available as Audacity 2.2.1 RC2: https://forum.audacityteam.org/viewtopi ... 46&t=97903
I would recommend trying this version as it contains several bug fixes. If you do so, please send us your feedback in this part of the forum: https://forum.audacityteam.org/viewforum.php?f=68
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 16 guests
