How to automatically clear all tags on UI-interactive saving
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by abdu » Sat Dec 02, 2017 3:20 am
How to automatically clear all tags on UI interactive save menu;
File > Save as other > Export multiple file
then up to Edit tag it prompts the user to edit tag of a n exported file... should he enter all the data repeatedly for 41 files ?
How to automate it please ?
abdu
Re: How to automatically clear all tags on UI-interactive sa
Permanent link to this post Posted by Trebor » Sat Dec 02, 2017 3:45 am
abdu wrote:... enter all the data repeatedly for 41 files ?
There are metadata editors specifically for that task, e.g. ... https://en.wikipedia.org/wiki/Mp3tag , (Batch Tag Editing).
Trebor
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 15 guests
