Audacity will not record on this computer
and the exact three-section version of Audacity from "Help menu > About Audacity".
Re: Audacity will not record on this computer
Permanent link to this post Posted by jesseshelnut » Fri Dec 01, 2017 1:12 pm
I am using an Audio Technica at2020. When everything is connected, Windows is able to detect something is there, but the green bar will not move.
jesseshelnut
Permanent link to this post Posted by kozikowski » Sat Dec 02, 2017 4:07 am
Terrific microphone. There is a YouTube home singer/performer I like and I think he has one of those.
That's the bad news. Audacity gets its sound from Windows, not the microphone or microphone system. If Windows can't hear it, that's full stop.
Does it still work in FLStudio?
I'm out of ideas. I do not like the odd adapter cable and Sabrent USB adapter. This is perfectly typical of "magic" failures that can happen with those two.
I have a nice, simple Behringer UM2 microphone and USB adapter. It seems to work perfectly every time I need it. It supplies 48 volt phantom power to microphones that need it.
I certified it for "perfect" overdubbing in Audacity. It has zero latency monitoring and will let you listen to yourself while you perform each part to a multi-part song. You will not be able to do that with the Sabrent system.
Screen Shot 2017-12-01 at 19.59.18.png (129.59 KiB) Viewed 119 times
They make a fancier UMC22 and there is also a Focusrite Scarlett Solo. All do the same job at increasing cost.
Previous
Return to Windows
Who is online
Users browsing this forum: No registered users and 15 guests
