SHIFT and Left-Click always plays from the start.
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Valentine Z » Tue Nov 28, 2017 6:13 pm
Hello there! First time on the forums, but have been a long-time Audacity user for personal projects.
So I recently downloaded and installed Audacity 2.2.0, and I realised that you can no longer loop from a specific point of the track. That is, let's say we have a 60-second track. I hold SHIFT, then click on 00:30, then unlike previous versions, this version will simply play from the start (00:00) and loop.
Last time, I can start from 00:30, all the way to the end, then loop. This helps me with larger files, because I can simply SHIFT + Left Click to the last few seconds, and just let it loop quickly.
Thanks in advance!
- Valentine
Valentine Z
Re: SHIFT and Left-Click always plays from the start.
Permanent link to this post Posted by steve » Wed Nov 29, 2017 1:57 am
Thanks for bringing this to our attention. It is a bug. The old behaviour 'should' still happen, but I see that it no longer does.
I'll log this on the Audacity bug tracker and hopefully it can be fixed soon.
Permanent link to this post Posted by steve » Wed Nov 29, 2017 1:57 pm
Just a quick update.
I've found the cause of the bug. It's now in the hands of the release manager to decide if it will be fixed in the next release. Fingers crossed :)
Permanent link to this post Posted by steve » Wed Nov 29, 2017 4:58 pm
And another update - It has been fixed for the next release, which is due out in December.
Permanent link to this post Posted by waxcylinder » Wed Nov 29, 2017 5:01 pm
steve wrote:Just a quick update.
Looks like the fix has been committed and thge bug marked DEVEL - FIX MADE - so there's a good chance. 8-)
waxcylinder
Permanent link to this post Posted by Valentine Z » Fri Dec 01, 2017 4:27 pm
Awesome, thank you for the quick fixes! :D Hoping to see it in the next patch/update!
- Valentine
Valentine Z
Permanent link to this post Posted by steve » Fri Dec 01, 2017 8:04 pm
Valentine Z wrote:Awesome, thank you for the quick fixes! :D Hoping to see it in the next patch/update!
You can try it now in the new 2.2.1 RC2: https://forum.audacityteam.org/viewtopi ... 68&t=97903
If you try this version (I'd recommend that you do as it is mostly bug fixes), please do give some feedback in this forum section: https://forum.audacityteam.org/viewforum.php?f=68
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 17 guests
