Can't record web-audio in Audacity 2.2.0 in Win 10,
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by doug3 » Mon Nov 27, 2017 9:55 pm
I believe Audacity needs to be fixed to allow web recording like it used to in older versions of Windows.
I can record web audio using another program called FastStone and I have spent 12 hours trying all the internet solutions with Audacity.
So I have done all the obvious things.
More information follows:
I have the latest versions of Windows 10 & Audacity= 2.2.0.
I right click the “Speaker Icon” in my tray and select “Playback” or “Recording Device”.
The PLAYBACK tab shows one & two green bars on far right side of screen (see below) & I can hear the sound from my speakers.
But the RECORDING tab {for either of my “Stereo Mix” devices} has no sound and no green bars on the right side of the screen.
Even when I go into Properties, select the “Levels” tab, & move the level from zero to 50 I still don’t get any sound.
For some reason, the level reverts to zero after a few seconds?.
Windows 10 also tells me the best drivers are already installed when I ask Windows to search for a newer driver.
I disabled all the microphones.
I ran the windows troubleshooter & it told me the audio device was muted & it was fixed, but still no recording sound?.
I am guessing this might be the Level gauge that reverts to zero after a period of time when I move it up to 50?
NOTE- I had pictures of the Windows popups to show the configurations I had tried (but they did not paste here) to I will try the upload attachment below
PLAYBACK WORKS: RECORD DOES NOT WORK=USB STEREO MIX: RECORD DOES NOT WORK =REALTEK STEREO MIX:
Audacty Problem.rtf
(1.44 MiB) Downloaded 9 times
doug3
Re: Can't record web-audio in Audacity 2.2.0 in Win 10,
Permanent link to this post Posted by DVDdoug » Mon Nov 27, 2017 10:21 pm
With Windows 7 or newer, use WASAPI loopback.
DVDdoug
Forum Crew
Permanent link to this post Posted by doug3 » Thu Nov 30, 2017 5:06 pm
:D :D Thank You Very Much. By picking the Host as WASAPI and picking a Recording Device that had LOOPBACK I was able to click the recording meter and see the levels as I recorded the web/YouTube waveform in Audacity. {ref is Audacity Manual: ( http://manual.audacityteam.org/man/tuto ... dows.html; ) adf.
doug3
Permanent link to this post Posted by crazyrev » Sat Dec 02, 2017 5:12 pm
I have a similar problem. I have just replaced my laptop and now use Win10. On my previous laptop, with Win 8.1, I could record web music (for personal use!) using "Stereo Mix (IDT High Definition). However, I now have only two options - "MS Sound Mapper" and "Microphone (Realtek High Definition)". Both of these record only from the inbuilt microphone. I have tried to attach a copy of the screen prints from each laptop!
I tried uninstalling 2.2.0 and then installing 2.1.0 as on my previous laptop, but it made no difference. I have now re-installed the latest version. If anyone can provide me with advice, or an alternative programme that will do the job I want done, I will be most grateful.
Thank you. :)
crazyrev
Return to Windows
Who is online
Users browsing this forum: No registered users and 10 guests
