What's Wrong Here..?
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by Maso » Sun Nov 26, 2017 7:04 pm
Why can't I get my Audacity to record...?
Yes, I have read the manual...
I'm on Windows 7 and I have my Audacity 2.2.0 version.
I am using a Behringer U-Phoria UMC22* unit with a studio quality condenser mic on a boom stand, it is a MONOPRICE Pro Audio Series 600800**. It has a three pronged jack plugged into my Channel 1 with it's gain set half way. Gain on Channel 2 is off... I have my 'Direct Monitor" toggle pressed "in" and it's "Output" knob half way at 12 o'clock. My +48V toggle is set to "On" position.
In my software I have all the parameters correct and double checked ( I think...):
Project Rate: 144,100 Hz.
Audio Host: MME
Line In: (Behringer USC WDM AUDI)
Recording Channels: 1 (Mono) Recording Channel
Playback Device: Speakers (Realtek High Definition)
I'm using Default Sample Format at 16 Bits...
* s/n: S1610641AUX; Date Code: 1610
** it draws it's power from my desk top 'puter through the USB.
So... I am getting the sound from my mic in my headphones okay.
But... when I click on the red "Record" button in the Transport Toolbar...
I get the curser movement from left to right in the Audio Track.... BUT NOTHING RECORDS...!!!
I have read and reread the manual and I cannot figure this out.
What am I doing wrong here...? Anybody...?
Maso... in distress. :|
Maso
Operating System: Windows 7
Re: What's Wrong Here..?
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 7:14 pm
I know about 44100. Is that a typo?
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 7:20 pm
Are you getting the little green signal light on the Behringer?
Can you get the red overload (CLIP) light? Never blow into a microphone, but keep speaking louder and louder and turn the volume up until the red light comes on. Using that volume and setting, start Audacity recording. Do you get any waves?
Permanent link to this post Posted by Maso » Sun Nov 26, 2017 7:47 pm
Yes... I'll edit that.
Maso
Permanent link to this post Posted by Maso » Sun Nov 26, 2017 8:03 pm
kozikowski wrote:Are you getting the little green signal light on the Behringer?
Hummm...
I do have a green light, yes.
I raised the Gain and got the red clipping light, then turned it down again.
I raised and lowered the Mic slider in the Audacity interface, nothing...
The condenser mic is supposed to be powered through the USB from the computer. I think that it isn't getting the power it's supposed to get. My mic has two toggle switches... One says: [ 0dB --- -10 dB ] and the other has a small horizontal line in its left position and a small broken line with an angle in its right position... I worked those two switches in all four of its possible combinations and got nothing.
Maso
Permanent link to this post Posted by DVDdoug » Sun Nov 26, 2017 8:34 pm
Your setup looks right (assuming 44.1kHz ;) ) and we know the microphone is working with phantom power, etc. Is the Audacity recording volume turned-up? (It's the slider with the microphone icon.)
You might try switching Audacity to stereo. Usually channel 1 is left or mono, but the Behringer may be different. And "just for fun", try input 2.
You can also try WASAPI and DirectSound as your audio hosts to see if one works. (This shouldn't make a difference, but WASAPI is the newest standard and MME is the oldest.)
...Unrelated - When you record in mono with a stereo interface both inputs are mixed (summed). The driver usually "leaves room" for two combined signals and with only one microphone/input you may be limited to -6dB (50%). That's not a big deal because you can boost the level digitally after recording.
DVDdoug
Forum Crew
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 8:59 pm
You didn't follow the instructions. Make a test recording while the red overload lights are on.
The UMC22 is a native mono device and should have no trouble delivering a show with Audacity set to Mono. There should be no 6dB error.
Many USB devices take away the volume control. The slider goes all the way up and stays there, but you can have one in Windows.
The bent line is a rumble and thump filter (low pitch tones) and should not affect normal voices. The 10dB switch is to reduce the volume in the case of a very loud performance, for example, playing a trumpet directly into the microphone. It's "fair warning" to the microphone you're going to present something loud.
You should be able to go into the Windows control panels and see sound activity. Audacity gets its sound from Windows, not the device. Right-click the speaker icon desktop lower right. And there you lose me. I'm not a Windows elf.
The microphone should have a light on it to tell you it's happy with the connection. In general, phantom powered microphones drop dead if the phantom power is low or damaged. Generally, Behringer devices are very good about that.
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 9:08 pm
Do you have any other connections between the UMC22 and the computer? I expect just the USB cable to be enough.
There have been instances where new users also connected an analog cable to the computer and used a bad connection on top of that, killing the recording.
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 9:29 pm
Apparently, the microphone has no "Phantom OK" light. Generally, if you can hear your voice at the UMC22 headphone connection and get an overload light, the microphone is OK.
The UMC22 +48v light is on, right? That's the voltage supplied to the microphone. That's the phantom power. It's called phantom power because it goes up the cable to the microphone and it doesn't affect the sound coming back down the same cable. Each is a phantom to the other.
This little dance requires a three-pin XLR cable. No adapters. The only option is plugging two XLR cables into each other to get longer length. One not-obvious advantage of these cables is the length. There is almost no practical limit. Try to keep them shorter than a hundred feet or so.
I'm using the overload light as a test. There is no condition where you would get the light during a normal performance. Also it's good to know how to get there and what the knobs and controls do at their extremes.
This is the "know your tools" thing.
Permanent link to this post Posted by Maso » Sun Nov 26, 2017 10:04 pm
Right now I am a little overloaded with all you're telling me. I will take some time to work on this...
The PR setting is 44,100 Hz... My typo.
My second channel is with only a standard phone jack. I plugged my Stratocaster in that and it also did not record.
I can get a clipping red light on my Behringer U-Phoria gadget as well as a through signal to my earphones if I turn up Gain... telling me that the mic works. The +48 volts switch in indeed on... All of my cables are standard length as they came... There is only one connection between the UMC22 and my computer and it is an USB type... I tried it in both mono and stereo... I tried all three available "Device" settings...
Afterthought... Could there be something wrong with my settings in my Windows 7...?
Maso
Next
Return to Windows
Who is online
Users browsing this forum: kozikowski, Vlad2 and 4 guests
