Internal Error in Equalization Preview [SOLVED]
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by Metaliched » Sun Nov 26, 2017 3:22 pm
Hello Audacity team,
I am using Audacity 2.2.0, and am running Windows 7. When using the Equalization function in Audacity, the "Preview" option doesn't work. I receive an "Internal error at WaveTrack.cpp line 1423" message. I am trying to preview Equalization effects on a single track of a multi-track session.
Your help with this matter will be greatly appreciated!
-Nick
Metaliched
Operating System: Windows 7
Re: Internal Error in Equalization Preview
Permanent link to this post Posted by steve » Sun Nov 26, 2017 3:28 pm
Metaliched wrote: "Internal error at WaveTrack.cpp line 1423"
It's a bug.
Please try the new "Audacity 2.2.1 RC1". This version should fix the problem. You can get it here: https://www.fosshub.com/Audacity-devel.html/
Re: Internal Error in Equalization Preview [SOLVED]
Permanent link to this post Posted by Metaliched » Sun Nov 26, 2017 4:06 pm
That did the trick! Thank you so much for your help, and quick reply!!!
Reason: marked as solved
Metaliched
Return to Windows
Who is online
Users browsing this forum: kozikowski, Trebor and 30 guests
