Error Writing Autosave File
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Kyleh » Sun Nov 26, 2017 1:23 pm
NEED HELP! when i paste a mp3/ any audio music something will always pop and it says like this
Couldn't write to file
"C:\Users\Navarro\AppData\Roaming\Audacity\AutoSave\Yo Gotti -
Rake It Up ft. Nicki MInaj - 2017-11-26 21-10-24 N-105.tmp": Error
Opening File
Reason: Topic split and givn relevant title
Kyleh
Re: Error Writing Autosave File
Permanent link to this post Posted by steve » Sun Nov 26, 2017 2:35 pm
Which version of Audacity are you using? (look in "Help menu > About Audacity")
How much free space is there on your C: drive?
Does the problem happen with all files, or only files which have a dot in the name? (it is generally safest to avoid using dots in file names, apart from the dot before the file extension. Safe characters for file names are letters, numbers, hyphen "-" and underscore "_". Spaces 'should' be safe, though some very old programs may complain.)
Return to Windows
Who is online
Users browsing this forum: DVDdoug and 10 guests
