Error while opening sound device
and the exact three-section version of Audacity from "Help menu > About Audacity".
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
Permanent link to this post Posted by Toby1501 » Sat Nov 25, 2017 8:41 pm
For some unknown reason, my Audacity 2.0.6, quit working today. Using Windows 10. When I go to Edit>Preferences>Devices, I have MME selected for Interface, under Playback / Device: Speakers, but under Recording / Device it says NO Devices Found, and the dropdown arrow says the same thing. Any advice as to how I fix this or where to begin?
Re: Error while opening sound device
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 1:11 am
The first that comes to mind is Clean Restart Windows.
Shift > Shutdown. Start. That cleans out the most existing Windows activities. Just because you shut Windows down normally doens't mean Windows forgot where it was or what it was doing.
Make sure all your devices and hardware are connected and working before you start Audacity.
If you get the service to come back, you might consider upgrading to Audacity 2.2.0.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], kozikowski and 12 guests
