importing music from itunes library
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by [email protected] » Fri Nov 24, 2017 11:27 pm
trying to use Audacity 2.2.0 on Windows 10 for first time.
I've successfully downloaded FFmpeg libraries but get an error indication each time I try to import anything from iTunes. What's wrong and what can I do?
[email protected]
Re: importing music from itunes library
Permanent link to this post Posted by kozikowski » Sat Nov 25, 2017 2:30 am
Some iTunes music is not available for production. Drag the music from iTunes onto the desktop. If it succeeds, then open it in Audacity.
Permanent link to this post Posted by DVDdoug » Sat Nov 25, 2017 4:37 pm
...each time I try to import anything from iTunes.
Try opening the AAC file(s) directly from your hard disc without opening iTunes.
* I assume you have AAC files? iTunes supports other formats (such as WAV & MP3) but AAC is the default and it you buy songs from Apple you get AAC.
DVDdoug
Forum Crew
Return to Windows
Who is online
Users browsing this forum: No registered users and 16 guests
