A question about Audacity's suitabliity
and the exact three-section version of Audacity from "Help menu > About Audacity".
Permanent link to this post Posted by Robert_ P_Eng » Thu Nov 23, 2017 9:10 pm
Hello forum users. I have an unusual question. I wish to create a home made noise cancellation device. Is is possible to have Audacity take a sound signal and produce the inverse of that input signal in real time? Am I looking to use the wrong tool for this application? I realize that I may have to learn some programming (with Nyquist?), however I do enjoy a challenge. In the event that I were to attempt commercialization (not a likely event), then royalties would be paid to Audacity.
Thanks in advance for any help and advice.
Regards,
Robert
Robert_ P_Eng
Re: A question about Audacity's suitabliity
Permanent link to this post Posted by steve » Thu Nov 23, 2017 9:30 pm
Audacity is not very suitable for that application. Audacity is primarily designed for "off-line" use - by that I mean, that you record something, then do something with the recorded data. Audacity doesn't do things "in real time", but rather "after the event".
Permanent link to this post Posted by steve » Thu Nov 23, 2017 9:31 pm
Permanent link to this post Posted by kozikowski » Thu Nov 23, 2017 10:08 pm
That's pretty much what this is.
Those are two electrically identical microphones with a "Y" cable. The sound mixer is on the top.
One of the microphones is phase cancelling "backwards." That's the extra "X" tube in one leg. Reverse pins 2 and 3. It doesn't pick up anything at all unless you get close and talk over one of the two microphones. It's used in very seriously noisy environments. It can give you a voice recording in the middle of an airport runway.
Permanent link to this post Posted by Robert_ P_Eng » Thu Dec 07, 2017 11:37 pm
Thanks for all of your help.
Robert
Robert_ P_Eng
Return to Windows
Who is online
Users browsing this forum: No registered users and 4 guests
