About SHA 256 as per required in MD5file.com
Hello there!
I just downloaded Audacity 19.34 MB | version: 2.2.0 from https://www.fosshub.com/Audacity.html/audacity-win-2.2.0.exe
As suggested in MD5file.com to check the check sum SHA 256 I got the following details:
audacity.exe (application/x-msdownload) - 10315440 bytes
SHA-1 dd82a72246d7808c87595aacdf4b1cfdce76c8eb
SHA-256 95f7e1a8fab5e20048b233d0167122f0ff72a961044e253726bc4d2c9055b949
SHA-384 001a7a1fea05765de37f720572709b7631a4c28511a4a8d0c102e271a652aec4a2415441807006e81f5bdd3877e6ab7a
SHA-512 1c2d18ff67ceb3d29c55257af8e4e6c71efd97b81f039cc483bfd415db5fa225279c8418cd629d07abc02736475e0b27cc445f4ddf808c713b7e395331aea488
unins000.exe (application/x-msdownload) - 1013925 bytes
SHA-1 c530dd732b48c831101a5cefc04232eece107fc9
SHA-256 f011883bbef70d85aab675ca7d904f208ab1c889da13a2a2f56dcc16f1a5d3de
SHA-384 6d4e43c4567c45211d3684cecb72077b3873682fedc28cc5e2562e61ff021a8939624a7fdad1919db1940f9636c1db18
SHA-512 bc2c5511bb3475903d32a06c4c850a24ae7da1ea3e24ee2f86648a76cada08403298a06a9abfcafd40ccc5948bbea29b21c6ec2bc223699cf76342bcfc9bdf58
But in http://www.audacityteam.org/download/online-safety-when-downloading/#validate there is To find the SHA-256 checksum: Audacity Windows Installer – 19.34 MB | version: 2.2.0
SHA256:adb0907d3be543f789bfa1dee10429d761ba858e320acf1b98ca5b4ef50b327a
which does not match with above SHA-256 95f7e1a8fab5e20048b233d0167122f0ff72a961044e253726bc4d2c9055b949
Have I downloaded the right .exe file?
Please somebody guide me.
Thank You
The quoted sha256 numbers refer to the download file, which should be called “audacity-win-2.2.0.exe”. Is that the file that you have tested?
I’ve tried it just now and I get:
and that matches the number quoted on both the Audacity website and the FossHub site.
Now I got the required checksum by choosing the file “audacity-win-2.2.0.exe” which I found in the Downloads Folder.
Thank You Steve. Your reply has made me in relief. Really appreciate your help. Cheers.
