Exporting tracks to ave the same length as the full song
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by jste » Tue Nov 21, 2017 1:54 pm
Hi everyone,
I have looked everywhere for this answer and can't seem to find it nor find it our myself. I am working on an audio project where some tracks' audios do not have the same length as the whole song but only start after a minute or so. However, I need to export them to have the same length as the full song and not only the length of its own audio (so basically - one minute of silence - audio - silence until the song ends) - how can I do this?
Hope somebody can help me! Thanks in advance :)
jste
Re: Exporting tracks to ave the same length as the full song
Permanent link to this post Posted by steve » Tue Nov 21, 2017 4:31 pm
When exporting a track, Audacity exports from the start of the first audio clip in the track to the end of the final audio clip in the track. Any empty spaces between these points is filled with silence. Empty space before the first audio clip in the track is not filled with silence.
If you need to export a track that starts after the start of the project (there is empty space before the first audio clip), and you want to include that empty space in the exported file, select a few seconds at the start of the track (doesn't matter how much, just select some of that empty space, starting from time=0), then "Generate menu > Silence" to replace the selected empty space with silence. The track can now be exported including the silence at the start.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Chapco and 15 guests
