blank progress box, minor bug
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by Steve Brown » Tue Nov 21, 2017 7:01 am
When I apply Equalization to a large project, the progress dialog box that pops up is blank while Audacity is equalizing. The previous version on my computer, 2.1.2, did not have that bug.
Steve Brown
Re: blank progress box, minor bug
Permanent link to this post Posted by steve » Tue Nov 21, 2017 11:06 am
I can't reproduce that here (on Linux).
Which operating system are you using?
Which version of Audacity?
Are you using the "Graphic Eq" or the "Draw" mode? Does it make any difference?
Are you using a preset, or your own custom settings? Does that make any difference?
Is the issue reproducible regardless of the settings?
Are you applying to a single mono track, or more tracks / channels?
Is this with a recording that you have made, or an imported file, or does that make no difference?
Anything else you can tell us about this issue?
Permanent link to this post Posted by waxcylinder » Tue Nov 21, 2017 11:49 am
I cannot reproduce that on W10 CE with either the released 2.2.0 or or on the alpha for the upcoming 2.2.1 :?
waxcylinder
Permanent link to this post Posted by Steve Brown » Mon Nov 27, 2017 5:22 pm
Steve Brown
Permanent link to this post Posted by Steve Brown » Mon Nov 27, 2017 7:24 pm
Well, this is embarrassing; it turns out I mis-reported the problem. It occurs when I export audio to a FLAC file. The progress dialog box is blank, and I've attached a screen shot. This problem did not occur in the previous version of Audacity I had installed, version 2.1.2.
Reason: Put image inline to preserve board layout
Steve Brown
Permanent link to this post Posted by steve » Mon Nov 27, 2017 9:03 pm
On Linux I don't see that, but I do see a problem. When exporting as FLAC there is no progress dialog window at all.
Permanent link to this post Posted by steve » Mon Nov 27, 2017 9:08 pm
Which version of Window are you using?
Permanent link to this post Posted by steve » Mon Nov 27, 2017 9:11 pm
Which exact version of Audacity are you using?
Permanent link to this post Posted by waxcylinder » Tue Nov 28, 2017 10:01 am
Good catch Steve Brown 8-)
Logged on our Bug-tracker as P3 Bug #1790: http://bugzilla.audacityteam.org/show_bug.cgi?id=1790
This is a recent bug that crept into 2.2.0 (was ok in 2.1.3 and earlier). Luckily you caught this just in time for us to hopefully squeeze a fix for it into the upcoming 2.2.1 release :D 8-)
Thanks for that,
Peter
waxcylinder
Permanent link to this post Posted by steve » Tue Nov 28, 2017 12:15 pm
steve wrote:Which exact version of Audacity are you using?
No need now, we've worked it out, but for future reference, it is very helpful if you include the full version number of Audacity, and details of your operating system, when you report a bug.
Thanks for your report.
Next
Return to Windows
Who is online
Users browsing this forum: lionshead007 and 15 guests
