Audacity with ASIO and Focusrite (Win 10) [SOLVED]
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by nopl » Mon Nov 20, 2017 11:51 am
Hi Everybody!
I have a Focusrite Scarlett 2i4. I would like to use Audacity with ASIO. I compiled it in Win8 as it's written in Wikipedia. It works fine on this computer.
I have a notebook with Win10 too. I would like to use the same compiled Audacity (and the Focusrite), but I have problems in this machine. If I change the interface settings to ASIO in Audacity, still no problem (only sometimes clicks and cracks while recording), but if I exit then start the Audacity again with this saved ASIO interface setting, all sound playback in Win10 will be like in slow motion, unlistenable (e.g. MP3 playing, Youtube etc.). The only solution is reinstalling Focusrite's drivers every time, it solves the problem - still using Audacity with ASIO again. Or I have to start Audacity with other interface setting (e.g. MME), then change to ASIO, use it, then change back to MME before exiting every time.
I don't know, what would be the problem, what is the difference, because in Win8 it works perfectly. Or I would have to compile Audacity with the Visual Studio in Win10, too? Can it depends on the operating system of the compiling?
Thank you very much in advance!
nopl
Re: Sound problem - Audacity with ASIO and Focusrite (Win 10
Permanent link to this post Posted by steve » Mon Nov 20, 2017 12:03 pm
nopl wrote:Or I would have to compile Audacity with the Visual Studio in Win10, too?
I doubt that is the problem. If your compiled version works OK on Windows 8, then it's pretty safe to assume that it's not a problem with the Audacity binary.
nopl wrote:if I exit then start the Audacity again with this saved ASIO interface setting, all sound playback in Win10 will be like in slow motion, unlistenable (e.g. MP3 playing, Youtube etc.).
It's important to remember that ASIO requires exclusive access to the audio device. Audio applications that don't use ASIO will not run properly (or more commonly "at all") while ASIO is using the device.
As for the difference between Windows 8 and 10: Probably the most important difference is "sound card drivers". Sound card drivers designed for Windows 7, 8 or Vista "may" work to some extent, but are very likely to have problems. For reliable performance it is essential that Windows 10 drivers are installed on Windows 10. Have you checked that your device drivers officially support Win10?
Permanent link to this post Posted by nopl » Tue Nov 21, 2017 8:50 am
Thank you for the quick answer!
There is only one version of Focusrite Scarlett 2i4 drivers for Windows as I see, and it's written in the homepage to be compatible with Win10 too.
nopl
Permanent link to this post Posted by steve » Tue Nov 21, 2017 10:34 am
and I presume that you have checked that your computer is using the 4.36.4 driver?
I don't think that this is an Audacity problem. I think that the problem is that on Windows 10, ASIO is not releasing the sound card as it did on Windows 8.
If you use Audacity with ASIO, then close Audacity and all other audio applications (including web browser), then wait for at least a full 10 minutes, then try playing an MP3, what happens?
What if you do a complete shutdown of the computer (not just go to sleep) and reboot after using Audacity with ASIO?
Permanent link to this post Posted by nopl » Thu Nov 23, 2017 10:48 am
I use the latest (4.36.4) driver.
The waiting and shutting down/rebooting didn't help, and I realized after detailed tests, that not only starting Audacity with ASIO settings can cause the problem - after changing once to ASIO settings in Audacity and exiting, next Audacity starts still cause this, regardless the interface set.
But I think I found the solution meanwhile! As I changed the buffer size in Focusrite's ASIO Control Panel, the problem has dissapeared, I didn't have to reinstall the drivers, and if I use other buffer size than the default (largest), this problem has not even occurred since then. I hope it's an ever-lasting solution.
Thank you for your help!
nopl
Re. Audacity with ASIO and Focusrite (Win 10) [SOLVED]
Permanent link to this post Posted by steve » Thu Nov 23, 2017 12:56 pm
Thanks for the update. I'll mark this as solved and hopefully it may help others with this problem.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], Vlad2 and 7 guests
