Correct order for applying effects
  • Please state which version of Windows you are using, the exact three-section version of Audacity from "Help menu > About Audacity".
  • Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at https://www.audacityteam.org/download/.
Permanent link to this post Posted by KS1 » Sat Nov 18, 2017 11:10 pm
Audacity 2.1.2
Windows 10
I would like to perform the following on our church service recordings
Noise reduction - Amplify(if applicable) – Compressor – Normalise
Is this the correct order in which to perform these operations?
Thank you in anticipation
KS1
Re: Correct order for applying effects
Permanent link to this post Posted by DVDdoug » Sat Nov 18, 2017 11:25 pm
That looks good. Generally, it's best to do noise reduction before compression of leveling because you'd like the noise to remain as constant as possible. (If noise reduction is working for you, great, but it usually doesn't work very well with the acoustic noises you're likely to pick-up in a church and if mics are faded up & down, the noise will vary making it difficult to remove/reduce.)
Note that Amplify can be used for normalization unless you want to normalize right & left independently, or if you need to fix an offset, etc. Depending on your compressor settings you may not need to normalize, but it "never hurts" to normalize as the last step.
DVDdoug
Forum Crew
Permanent link to this post Posted by KS1 » Sun Nov 19, 2017 9:32 pm
Thank you very much for your very prompt reply – I'll experiment with your suggestions
Best Wishes
KS1
Return to Windows
Who is online
Users browsing this forum: No registered users and 24 guests
